configure cfm segment frame-loss consecutive
configure cfm segment segment_name frame-loss consecutive frames
Description
This command is used to configure the number of consecutive measurements to be used to determine the availability status of a CFM segment.
Syntax Description
segment_name
Alphanumeric string identifying the segment name.
frame-loss
Y.1731 Ethernet frame loss measurement.
Default
10.
Usage Guidelines
This configuration is optional.
configure cfm segment cs2  frame-loss   consecutive 10
This command was first available in ExtremeXOS 15.1.
Platform Availability
